  1. erikoraka
  4. Tuesday, 06 July 2021
I want to use the Cera Pro Regular fonts in my Emani website (https://www.arthrojoint.gr/joomla/).
I have downloaded the ttf file.
Can you please tell me how can I upload the aforementioned font and use it in my Emani template?
Best regards
Can you please advise whether I could use the aforementioned font in my Emani template and if so how this is done?
Thank you in advance,
Eri
Hi Eri
Sorry to say we have no 'easy' option for adding your own font via the template settings. You can try adding the font manually as described in the following post.. https://joomla51.com/forum/resonate-template-arabic-font
I followed your advise and added the following to my css after uploading the attached ttf (please after downloading omit the .txt extension in order to read it..) in the fonts folder of my Emani template:
@font-face {
font-family: 'CeraPRO-Regular';
src: url('fonts/cera-pro-regular.ttf') format('truetype');
font-weight: normal;
font-style: normal;
body {
font-family: 'CeraPRO-Regular' !important;
..it seems that it did not work..Can you please indicate my mistake in following your instructions?
Actually the font effect I would like to get is the one you can see in the following site:
https://osteon.gr/
Thanks again!
Eri
should be
src: url('../fonts
I replaced with the following:
src: url('/http://arthrojoint.gr/joomla/templates/j51_emani/fonts/cera-pro-regular.ttf') format('truetype');
but still nothing if this is what you meant..:(
I have the impression that some titles change (i.e. h2 titles if I can see right) but not every text change (i.e. menus, body etc)..
Kind reminder on my request above :)
Thank you once more!
Eri
Hi Eri
Have you tried adding your CSS to the custom CSS field of your template settings? I have searched through your site source and have been unable to locate your CSS been loaded.
To be honest I tried the css you indicated and as it didn't work I used another of google available fonts..:)
Hello Ciaran!
I am near the go live of the following site I am developing and I still have not found a way to use a modern greek font...
Can you please help me with using for example the cera pro font (see attached) in my Emani template?
I tried using your instructions above but with no luck..
Please advise..
I am also sending you in the email the details for temporary access.
Thank you in advance for you help.
Kind regards,
Eri
Hello Ciaran!
Kind reminder on my request above as I am waiting in order the site to go live..:)
Thank you so much for your help!
Best regards,
Eri
Please close the issue...I found a solution myself..by choosing one of the google fonts instead..
