1. eumel7
  4. Monday, 19 December 2022
Upgrade Bianca Template from J3 to J4
I have the following display errors after upgrading a Biance template page J3 to J4, which I think has something to do with the template.
1. The "search" (search index) in the module position header2 is incorrectly formatted (image 1.jpg and 1b.jpg)
2. The main posts on the "Home" page menu link are displayed in the post settings with the "Images and links" setting. These are incorrectly formatted after the update and sit above the post instead of to the left of the text (image 2, 2b, 2c, 2d)
3. The "alternative blog layout" doesn't seem to work at all. Since a blog layout setting was selected for a specific category under the menu item: "Club Reports". The frontend display remains empty. The template supplied is used: Category Blog - Alternative (image 3 and 3b)
Link Original J3: https://www.dynamofanclub-sayda.de/
edit: I recreated these errors on a completely different domain with the same template, the same errors.
Attachments (8)
Note that since between Joomla 3 and Joomla 4, the base CSS framework has moved from Bootstrap 2 to 5 which has caused some differences in styling in particular with form elements.
.header-2 .js-finder-search-query {
padding: 4px 6px;
border-radius: 14px;
font-size: 12px;
2. We will create a template update for this issue. In the meantime, to amend also add the following to your Custom CSS...
.blog-item {
display: block;
.blog-item .left.item-image {
float: left;
margin-right: 2rem;
3. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Thank you for answer
1. Ok run
2. it's Ok a update for the template
3. email sending
Hello Ciaran.
May I bring this thread up again?
the problems in 1. and 3. are solved.
The error under "2." has not yet been entered into the Bianca template (1.1.7.). The code you set here works, but, like in the original J4 template, the colored bar above the image is still missing...
Can you please update the template?
  1. http://fanclubtest.onlineshop-nitzsche.de/index.php
Hi eumel7
Thank you for pinging me on this. I somehow missed it the first time of asking. I have just created a new update for the Joomla 4 Bianca template adding the 'highlight' to article images as available on the Joomla 3 version.
Thank you for the fast reaction.
I imported the template update from version 1.1.7 -> 1.1.8 to two J4 "Bianca" pages.
in connection with the code inserted here above, the page now looks like in the J3 version again!
But: If I omit the code from Posting 2, the colored bar now appears, but the introductory image is still above the text! (see the screenshot)
I'm OK with connecting the code, but I don't know if other people who aren't reading this post will have problems...
Decide for yourself...
Best regards Marco (eumel7)
Thank you Marco
This issue appears to be specific to the featured articles layout. I have just created another update which should resolve this issue.
