1. Tralala
  4. Wednesday, 03 May 2017
I made another website with one of your templates: Elvira.
Last weeks I struggled a lot to eliminate the vegas-wrapper - we don’t need an any slideshow. Hard to do, but I seemed to manage it.
But there is still a problem.
Please see https://b-a-n-g.nl/ .
Switching to any page moves the header downwards for about 0,3 second. Very irritating. How could I switch off this move?
I already modified some css-code:
#container_header {transition:all 0s ease 0s;}
#container_header * {transition:all 0s ease 0s;}
But the unwanted move did not disappear.
How to avoid this move?
If you’d like to have a look in the backend - I made a login for you.
  1. https://b-a-n-g.nl/
#container_slideshow {
    display: none;
Thanks. Unfortunately this is not the soloution for the problem.
The problem is: switching to any other menu-item moves the whole website downwards about 110px for about 0,5 second.
I just checked the Elvira-demo on joomla51.com and there’s the same ‘problem’, so it seem to be a deliberate part of the template.
But why? In my website this is absolute inacceptable.
So Ciaran, I beg you for a way to get rid of this strange effect.
I now see your issue.
To amend you can add the following to the Custom CSS field of your templates parameters...
#container_header {
    left: 0;
    position: absolute;
    right: 0;
    top: 0;
Alternatively you can update your template to the latest download which has this fixed applied... http://joomla51.com/tutorials/item/updating-your-template
Tanks a lot! This doet the job. Great.
I wouldn't have find this solution myself.
Was exactly what I was looking for, too!
Thank you!!!
Steph H.
