1. onyxingenuities
  3. Friday, 17 January 2014
I have tried to use the Unite Revolution Slider in several of your templates, namely the Kindle and Renovation templates, but there seems to be formatting issues within the showcase module position that prevent it from working. I was wondering if there was a work-around to allow this slider to work?
Would you have a URL to an example of the styling issues you are having?
onyxdm.com
I have the parameters on the slider set to full width, but as you can see on this site, the frame it creates is 1130px and no images are displayed. Thanks for you help!
Chris
Hi Chris
Try adding the following to the Custom CSS field of your templates parameters...
.slideshowcontainer {
max-width:100%;
width:100%;
#body_bg {
box-shadow: 0 -5px 20px rgba(0, 0, 0, 0.2);
#container_slideshow {
padding:0px;
The images not appearing could be a slideshow issue rather than a template issue. To confirm this could I ask you to try the slideshow using one of the default Joomla templates (Beez) and see if the problems persists? If so may I suggest contacting the developer of the slideshow.
