1. damador
  3. Monday, 13 October 2014
Email from septembrer 1:
I have added the following to the Custom CSS field of your templates parameters, forcing the width of your GridGallery images in these module positions...
.top-3 li.j51gridgallery {
width: 160px;
Joomla51
My response on october 10:
Hi Ciarán:
Thanks to your help, i have solved the problem of the grid-gallery modules in the top-3 position in my lap.
But now my problem is this: My six grid-gallery in top3 modules are cut in home in all the tabs (im using ipad 3).
I try change the width measures without success in tabs.
It is possible to do something?
As always, the problem occurs only in the home.
Thanks a lot in advance,
Damador
http://www.seccionmedicadetampico.com.mx
You apper to have set up your GridGallery module in a somewhat unconventional manner. Rather than simply creating one instance of the module and adding all your images to it you have created an instance of the module for each of your images. Setting up your module in this way is causing a number of these issue you are having.
All I can suggest is to try adding the following to the Custom CSS field of your templates parameters, editing to your own taste...
/* iPads (portrait and landscape) ----------- */
@media only screen
and (min-device-width : 768px)
and (max-device-width : 1024px) {
width: 100px;
Thanks a lot Ciarán,
It works fine...
Damador
