1. erikoraka
  4. Wednesday, 27 July 2016
I downloaded Trinity template but when i try to upload it to the website I get the following error:
Warning
JInstaller: :Install: Can't find XML setup file.
Error
Unable to find install package
Can you please advise?
Kind regards,
Eri
Thanks for the reply Ciaran!
I three other issues with the mobile version:
1. In the following link http://www.megarevma.gr/chara/index.php/contact-us, in the mobile version of the site the menu desapears
2. In the following link http://www.megarevma.gr/chara/index.php/collections/ss2016, in the mobile version of the site some of the side-by-side photos are not in the same height
3. When I open the menu in the landscape version, all the sections are not shown and I cannot scroll down in order to see the rest of them! I can only see up to the sub menu "Our Team" and the rest that are below I canno scroll to see!
Please advise!
Thank you in advance,
Eri
Hi Eri
1. May I suggest the following article on this query.. https://joomla51.com/tutorials/item/resolving-javasript-errors-in-joomla-using-jquery-easy
2. To amend try adding the following to the Custom CSS field of your templates parameters...
table td {
vertical-align: top;
3. To amend try adding the following to the Custom CSS field of your templates parameters...
.slicknav_menu {
box-sizing: border-box;
position: relative;
Thank you Ciaran,
And something else..
Regarding 2. now that the photos alignment is fixed the text alignment is not..The description of the photos in some cases does not appear just at the bottom of the photos but leaves a space..
Can you please also advise on this too?
Thank you again,
Eri
Hi Eri
Unfortunately we are unable to resolve this issue. The issue appears to be related to the content of your table rather than the table itself. It is worth noting that tables are not an ideal solution for optimal viewing on mobile devices.
I removed the table and I put the images side by side. In the desktop version the images appear side by side (that's fine!) but in the mobile version they appear one below the other. How can I make the images in the mobile version appear in two columns, side by side, without using a table?
Thank you again!
Eri
Hi Eri
a.jcemediabox-image {
display: inline-block;
max-width: 100%;
width: 48.5%;
Thanks Ciaran it works fine!
Another thing now: in the contact us form I have created (http://www.charalkaftans.com/index.php/contact-us) I get the following message when I try to send an e-mail: Notice Could not instantiate mail function.
Thanks again,
Eri
Hi Eri
Sorry to say this would not be a template related issue. May I suggest the following article to ensure your mail settings are correct... https://www.siteground.com/kb/how_to_setup_mail_in_joomla/
Thanks for the answer Ciaran, maybe I'll ask my hosting provider also.
Can I also ask you where do you think is better to add the Website developed by Eri Koraka note in the Trinity template so as to be discretely shown? Is this done using CSS?
Please advise..
Thank you again for your help!
Best regards,
Eri
Hi Eri
Have you considered using the copyright area of your template which can be edited via the 'Copyright' tab of your templates parameters?
Thank you Ciaran, I used the Copywrite tab and it looks fine!
Can I put an e-mail link at the name Eri Koraka also?
And something else...
Can you tell me if in the mobile portrait version of the website I can adjust the triangle logo area so that it won't show from the one side of the screen to the other but adjust accordingly?
Thank you again!
Eri
Hi Eri
Have you tried adding your email via HTML within the copyright field?...
<a href="mailto:[email protected]">[email protected]</a>
Sorry to say there is no option available to allow the logo triangle to resize on smaller screens.
