1. NemesisNG
  3. Tuesday, 06 December 2016
Hi, is there any way to make the menu sticky at the top of the screen when scrolling down the page as in the Chelsea template, so that it is always visible? Might not be an easy change but would be very useful. Thanks.
Considering how the Trinity template is laid out I am sorry to say this option is not available with our Trinity template. You could try adding the following to the Custom CSS field of your templates parameters however you will experience some issues if you wish to use the header slideshow option...
#header_bg {
position: fixed;
top: 0;
width: 100%;
#header_slide {
position: relative;
Thanks, I did think it might be difficult to implement. Might try a different template then and see how I get on. Cheers.
