1. webdesignkummert
  3. Friday, 16 January 2015
each post has a white background in the template Journal.
Where can I get the background (css: opacity) regarding the transparency change.?
Thank You!
To set an opacity to the article area of your template try adding the following to the Custom CSS field of your templates parameters editing to your own taste...
#container_main .wrapper960 {
background-color: rgba(255, 255, 255, 0.7);
thank you, we find the solution.
Best regards
