1. hugovandenbogaard
  3. Wednesday, 28 June 2023
The top menu is too high. How can I lower it so the logo is more visible?
Kind regards
Template j51_hayley Joomla 4
Thank you very much for your response. I was able to change it. Kind regards, Hugo
Would you have a URL to an example of your header?
Good evening,
Thanks for your help. Is it also possible that the menu bar will be slightly higher.
Kind regards from the Netherlands Hugo.
http://test.hugovandenbogaard.nl
  1. http://test.hugovandenbogaard.nl/
Presuming I understand you correctly, to amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.logo {
padding-block: 10px;
(edit to taste)
