MENU
  1. ziggy
  4. Thursday, 18 April 2013
Dear Support-Team,
I'am using your J51_Oxygen template for Joomla 3. First - thank you very much for developing and making it free available!
Now my biggest problem. Just like other users here, I can't save changes on articles when edited in front end. Clicking on the "Save" button has no effect.
Second, I'm using a side menu in sidecol a and a Facebookbox in sidecol b. Therefore the main body is very thin. For normal use that's ok but when activating the editor, it is overlayed by the Facebookbox. Is it possible to make the whole template a bit wider?
Third, I want to use a Captcha for User-Registration, but it seems that there is not enough space for the captcha.
Could you help me? May I send you an eMail with an admin-account?
Thanks for your help!
Thank you!
the new download works! Now I try the resizing.
Hi Simon
For the save and captcha issues may I suggest using the latest download of the template which should amend both of these issues (http://www.joomla51.com/templates/j51-oxygen-free-joomla-3-template).
As this template is largely image bases it can be a bit tricky resizing as a number of the images have to be edited to your new width. For further details may I suggest the following post.. http://www.joomla51.com/forum/support/free-templates-extensions/extend-the-width-of-oxygen-template#2176
