1. thebizwizard
  3. Sunday, 26 January 2025
Testimonials J4 and kinvara template Joomla 5.3.2. Module display is weird No slider, HuGE black quote mark, testimonials stacked one on top of another. See attached screenshot
Hello thebizwizard
Which version of the module are you using in J4?
For me, version 1.0.5 is displayed!
Using this version of testimonial - mod_j51testimonials_j4
The website is Joomla 5
I have reproduced your error. I have the same problem. (J! 5.2.4 an Testm. V.: 1.0.1)
ciaran also the module version 1.0.5. causes the same error with this template (kinvara V. 1.0.1.)
It works with a different template...(e.g. kodaline)
Thanks! I installed a different version of the module and it is workine fine now!
Which version?
Hi eumel7
The latest version of the testimonials module (1.0.5) should be available to your via Profile -> Extensions Downloads.
Hi ciaran
Thanks! But I know that.
As I wrote in my 3rd post. This exact version 1.0.5 does NOT work with Kinvara 1.0.3!
(it works with another template of yours)
It's a shame that the person who started the post ( thebizwizard ) didn't write what version he has?
Look further up the thread, I did indicate the version -
Using this version of testimonial - mod_j51testimonials_j4 - The website is Joomla 5
the name testimonial - mod_j51testimonials_j4 is just the file name.
This is always the same after the download. The version of the module you have installed can be found as follows: In the Joomla backend under:
SYSTEM -> Extensions. There you search for: "J51_Testimonials" then the installed module appears and under: the VERSION tab you can see the installed version... See image
This is the one I installed that works.
Ok. It works for me with 1.0.1 too.
It doesn't work with 1.0.5...
