1. AlisonAMG
  4. Sunday, 12 November 2023
Hey Ciaran
I'm late to the party reporting this because I've just been clearing the error_log vs taking the time to chase things down.
I'm running Hayley J3 on this site. Expect to migrate during their next update run at the end of the year. I've checked and there is no Hayley update for J3 in some years. Template is working fine but it is errors off the Testimonials portion. I know where we download template updates but is there another spot for bug fixes to the various plugin/modules included with your various templates?
URL is barrygoldstein.net
[12-Nov-2023 15:39:24 UTC] PHP Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in /home/barrygoldstein/public_html/modules/mod_j51testimonials/mod_j51testimonials.php on line 18
[12-Nov-2023 15:39:24 UTC] PHP Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in /home/barrygoldstein/public_html/modules/mod_j51testimonials/mod_j51testimonials.php on line 23
[12-Nov-2023 15:39:24 UTC] PHP Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in /home/barrygoldstein/public_html/modules/mod_j51testimonials/mod_j51testimonials.php on line 24
[12-Nov-2023 15:39:24 UTC] PHP Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in /home/barrygoldstein/public_html/modules/mod_j51testimonials/mod_j51testimonials.php on line 30
[12-Nov-2023 15:39:24 UTC] PHP Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in /home/barrygoldstein/public_html/modules/mod_j51testimonials/mod_j51testimonials.php on line 31
This also repeats but not sure where to look on it;
[12-Nov-2023 15:39:24 UTC] PHP Deprecated: trim(): Passing null to parameter #1 ($string) of type string is deprecated in /home/barrygoldstein/public_html/libraries/vendor/symfony/yaml/Inline.php on line 49
Many thanks,
Ali
NB: Using Hayley on another site - up to J5 no probs so is just J51-Testimonials.
Hey There
No word back on this yet. The error_log that I set back to empty on Sunday morning prior to my previous post is now up to 110.45 MB of error messages. It had previously grown so large as to set off storage warnings in the hosting space for my client (several GB). Could you let me know what templates have a more current release of J51_Template so I can replace the old one that would be great.
Thanks so much,
Ali
Hi Ali
Many thanks Ciaran
Email on it's way.
Big thanks for getting in there so quickly. I have reset the error_log back to 0 and hopefully your adjustment has got things fixed up. :)
Good morning. Error log back up to 50MB again this morning. The previous errors are all gone. YAY But now it's full of this one over and over. Hoping someone can point me in the right direction on it.
[14-Nov-2023 21:04:27 UTC] PHP Deprecated: trim(): Passing null to parameter #1 ($string) of type string is deprecated in /home/barrygoldstein/public_html/libraries/vendor/symfony/yaml/Inline.php on line 49
Many thanks to anyone taking the time to consider this.
Ali
EDIT UPDATE: I ran this in the J FB group. From Roberto: I guess you have php 8.1 which deprecated sending null to a lot of php functions. While you find a proper fix or until you migrate the site you can downgrade php to 8.0.
Hi Alison
If you set the Error Reporting option in your global configuration (Global Configuration -> Server -> Error Reporting) to Maximum and then refresh the page, do you get any errors on the page indicating the source of the issue?
Hey Ciaran
I turned it back to PHP8 for now. It isn't showing anything on it.
Frustration level right now is about a 12/10 on all things Joomla and this isn't the pressing priority ATM.
Thanks Alison
