Firstly thanks for a beautiful template. I have a few problems with this template and it might be due to me not doing things right.
1) The Text Seperator on the menu item treats that menu item as pure text and does not allow for the child menu items to open up or appear if its set to Text Seperator. If I change that item to Single Article or something else it then functions BUT I would prefer not to as I would like to use the menu Item to group other menu items together.
2) I am using YooThemes Widgetkit and specifically the gallery. when the image opens up the Site title as well as the Menu items appear above the image (on top of the image). Is there a possible easy fix for this that you are aware of.
URL to see: http://test.drab.co.za/
Notice Dealers Near You...By hovering over it or clicking it does not open the child menu options...unless I set display children on and then it displays it the whole time. The effect I am after is the when the option is clicked the children will display without having to load a new page ie: single Article etc...but by using a Text Seperator or something similar.
Thanks in advance...
