1. Stanicki
  3. Thursday, 06 August 2020
Templates
J51-Bianca
J51-Sophia
In these templates, the mobile menu is not clickable, the menu cannot be opened. Thank you in advance for every hint
ok mail wysłany
same problem:
J51 - Carmen
Thank you Stanicki
Disabling your plugin 'PLG_SYSTEM_CIACHO' appears to have resolved the issue.
Note we were unable to access your site using the Sophia template. If you are using the same plugin for this site, try disabling it and see if the issue persists.
thank you very much the problem seems to be solved. Many thanks for professional help
HI Ciaran,
same issue here with Bianca template. I did not find the PLG_SYSTEM_CIACHO plugin. I suppose to grant you access rights to the page. ;) Link is comming.
BR Torsten
HI Ciaran,
same problem with Sophia template. I did not find the PLG_SYSTEM_CIACHO plugin.
BR Bee
