1. abseve
  3. Monday, 26 January 2015
How do we fix this error?
templates/j51_habitat/js/scrollview.js Failed to load resource: the server responded with a status of 404 (Category not found)
I found some similar forum entry but it is the cashmere template.
I thin this is the reason why the before and after image plugin is not showing the full image when you first get to the page. if you refresh the page it show the full image. This is the only show in the javascript console as error.
Hi!
Is there already a solution for this problem? I'm having the same issue with the template (Habitat). :(
Thank you!
Manfred
Hi Manfred
In your templates index.php (../templates/j51_habitat/index.php) you can remove the following as it is no longer needed (line26)...
<!-- Scrollview-->
<script type="text/javascript" src="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template ?>/js/scrollview.js" charset="utf-8"></script>
Hi Ciarán!
Thank you very much!! By the way, your templates are awesome ;)
Manfred
