1. alvin77
  4. Thursday, 10 November 2016
Hy Ciaran
I have aproblem with Template Width in configuration.
It is 1080px and is very good on small screen like tablet or small desktop monitor (17 inches).
On a screen of 21 inches or on a screen that resolution is > di 1280*800 is not good (see the example imgae)
Can i set in css only for big monitor (or small resolution > di 1280*800) another template width?
I see that there is the possibility to set in template configuration thw width but if i set there then is not good on screen < 1280-800.
So i'd like to set only for monitor with resolution >1280*800 another template width (see example.jpg resoltuion is 1920*1080)
url:http://www.madeinporte.altervista.org
@media only screen and (max-width: 1280px) {
.wrapper960, .backgrounds .content_background {
width: 1280px;
Thanks Ciaran yuo are always helpful!!
Seems to work with this setting in custom.css and probably if i set width for different resolution solve my problems.
The template that yuo sell have the same problem or only for free templates yuo have to set width for different resolution?
By default all templates have a set width. I suspect you wish to make your website width fluid which can be done with the following Custom CSS...
width: 100% !important;
  3. # 3
thanks ciaran i will try this solution.
Can yuo tell me something about j51 icon?
From the image yuo can see that the icon AFFIDABILITA' is not aligned in some resolution.
Wich is the problem?
  3. # 4
On what screen resolution are you having this issue?
  3. # 5
For template widht i tried yor solution but with the first on screen with resolution (big then 1280)is not good and with the second the mobile template lost the correct resolution. What can i do for have a temolate widht good on all device and resolution?see http://www.bioksport.it with template helix 3 the site is good on all device and resolution
  3. # 6
