1. fume
  3. Wednesday, 20 March 2019
I have read that the modul position showcase does not work for Sophia. It works with showcase-1a. Here is my question:
I don't need a slideshow. In my project I have for every site only one single picture. Is it possible to use the custom modul? If yes, how can I arrange it?
One big reason is the reduction of javascript => performance.
It appears your image is wrapped in a paragraph tag. To remove the paragraph bottom margin you can also add the following to your Custom CSS field...
.showcase-1 p {
margin-bottom: 0;
Yes a custom module can be used by simply adding the image to the module an placing it in the showcase-1 module position. Note if you wish the image to be centred/ full width you can add the following to the Custom CSS field of your template settings..
Edit to taste.
.showcase-1 img {
margin: 0 auto;
display: block;
width: 100%;
Thank you, it works. I could reduce page size an requests.
Only one point I couldn't solve. I added height with 100 %. But there is still a black stripe below the picture.
.showcase-1 img {
margin: 0 auto;
display: block;
width: 100%;
height: 100%;
Great! This was the solution. Thank you.
This is the link.
