1. Turbomay
  4. Sunday, 05 July 2020
please... can you help me again. Take a look to the attached screenshot. The slide is not working with the Layer Slideshow Module!
The Lite Module is running fine, but I do not want to use it.
I will send temporary administration access to this Joomla installation to [email protected].
URL: http://www.rheinprotekt.de
Thanks for your help again
Frank
  1. http://www.rheinprotekt.de
Thank you Frank
Updating your template to the latest download appears to have resolved the issue.
Thank you Ciaran
sorry but the animation title and caption is not working!
What the hell is it. Another problem I could not select the JCE-Editor in the configuration.
Frank
I solved the problem JCE-Editor :D ! It was deactivated and other moduls too.
Only the animation in the Layer Slideshow Module is not working.
Thanks Frank
I'm again...
is this the problem error message in Google Chrome Browser "Console":
DevTools failed to load SourceMap: Could not parse content for https://rheinprotekt.de/media/j51_assets/sourcemaps/tiny-slider.js.map: Unexpected token < in JSON at position 0
DevTools failed to load SourceMap: Could not parse content for https://rheinprotekt.de/media/mod_j51layerslideshow/css/sourcemaps/tiny-slider.css.map: Unexpected token < in JSON at position 0
Frank
Hi Frank
Clearing your site cache appears to have resolved the issue? ENsure that you do a full refresh on your browser (CTRL/CMD + F5)
Thank you Ciaran... it is working fine :D !
i find a similar problem with the module "mod_j51news" and the module "mod_j51layerslideshow". I have download the last version of template Layla. I have installed it with all the module. I have the same problem. I do a full refresh on two browsers.
The file templateDetails indicate :
<version>1.0.5</version>
<creationDate>August 2020</creationDate>
and not the 1.0.6 version ...
Errors on the dev console :
DevTools n’a pas pu charger SourceMap : Désolé... Nous n’avons pas pu charger du contenu pour http://xxx.fr/media/mod_j51news/css/sourcemaps/tiny-slider.css.map:Erreur HTTP : code de statut 404,net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools n’a pas pu charger SourceMap : Désolé... Nous n’avons pas pu charger du contenu pour http://xxx.fr/media/mod_j51layerslideshow/css/sourcemaps/tiny-slider.css.map:Erreur HTTP : code de statut 404,net::ERR_HTTP_RESPONSE_CODE_FAILURE
There is not folder sourcemaps in media/mod_j51news/css/ and mod_j51layerslideshow/css/
I suppose that is a simple problem of call to the ressource.
Thanks!
I have not receive a response of my question. This morning i send you a mail again of this subject with access code.
Strangely we have tried to update your modules however the CSS in your media folder is not updating. To fix could I ask you to amend the following files manually...
https://localhost/build/nina/media/mod_j51layerslideshow/css/tiny-slider.min.css
https://localhost/build/nina/media/mod_j51news/css/tiny-slider.min.css
At the bottom of each file, remove the following...
/*# sourceMappingURL=sourcemaps/tiny-slider.css.map */
