1. Josie
  3. Sunday, 30 October 2022
we have a problem with google fonts in free template oxygen.
We deleted the links in the styles.php (rows 13-53) like it was written in https://www.joomla51.com/forum/google-fonts-eu-dsgvo#reply-28949, but they are still there. Can we delete the googlefonts.php to get rid of them?
Sorry for my belated reaction.
First thank you for answering, but problem is meanwhile solved.
But may I ask another question: we would like to try your responsive template "Ashley" Am I right that I have to remove the lines 16 to 29 in the styles.php for removing google fonts?
<?php
defined( '_JEXEC' ) or die( 'Restricted index access' );
include ("convert_rgb.php");
$document->addStyleSheet('templates/'.$this->template.'/css/bootstrap.css');
$document->addStyleSheet('templates/'.$this->template.'/css/typo.css');
$document->addStyleSheet('templates/'.$this->template.'/css/jstuff.css');
$document->addStyleSheet('templates/'.$this->template.'/css/animate.css');
$document->addStyleSheet('templates/'.$this->template.'/css/vegas.css');
if ($fontawesome_sw) {
$document->addStyleSheet('templates/'.$this->template.'/css/font-awesome.css');
$document->addStyleSheet('templates/'.$this->template.'/css/nexus.css');
<?php
$googlefonts = array($body_fontstyle, $h1head_fontstyle, $articlehead_fontstyle, $modulehead_fontstyle, $h4head_fontstyle, $hornav_fontstyle);
$websafefonts = array("Arial, sans-serif", "Arial, Helvetica, sans-serif", "Courier, monospace", "Garamond, serif", "Georgia, serif", "Impact, Charcoal, sans-serif", "Lucida Console, Monaco, monospace", "MS Sans Serif, Geneva, sans-serif", "MS Serif, New York, sans-serif", "Palatino Linotype, Book Antiqua, Palatino, serif", "Tahoma, Geneva, sans-serif", "Times New Roman, Times, serif", "Trebuchet MS, Helvetica, sans-serif", "Verdana, Geneva, sans-serif", "Arial");
// remove websafe
$googlefonts = array_diff($googlefonts, $websafefonts);
// remove duplicates
$googlefonts = array_keys(array_flip($googlefonts));
// remove spaces
$font_subset = str_replace(' ', '', $font_subset);
// loop
foreach ($googlefonts as $v) {
echo '<link rel="stylesheet" type="text/css" href="//http://fonts.googleapis.com/css?family='.$v.':400,500,700&subset='.$font_subset.'" /> ';
<?php if($responsive_sw == "1") { ?>
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1"/>
<link rel="stylesheet" href="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template?>/css/responsive.css" type="text/css" />
<style type="text/css">
@media only screen and (max-width: 1140px) {
.wrapper960 {
width:100% !important;
#container_footermenu {
padding: 20px;
@media only screen and (max-width: <?php echo ($menu_break); ?>px) {
.hornav {display:none !important;}
.slicknav_menu {display:block;}
</style>
Yes. Specifically, you need to remove line 27.
  3. # 3
