1. salinger
  4. Tuesday, 07 October 2014
I had oxygen and the Autson Slideshow installed (joomla 2.5) on http://www.pferdepraxis-wallernhof.at...Unfortunately the slide show seem to be virus infected so I had to delete it. I installed J51 slideshow from another template. Jquery is on, the path to the pictures is correct, but there is nothing to see on the home-page, not even the title of the slideshow. I checked out the troubleshooting and went through all points, nothing helped.
I tried to install another slider, the same problem again, nothing is visible.
Can you please help once more?
Kind regards Marion
Hi Marion
Ensure you have jQuery enabled within the modules parameters as this is not loaded by default in Joomla 2.5
HI Ciarán,
of course I did that, I wrote it in my mail :-)
regards, Marion
Shucks... sorry Marion.. dont know how I missed that! :blush:
Thank you Marion
Your slideshow should be now appearing correctly.
Your slideshow was assigned to appear on the 'Home' menu item however it is your 'PFERDEPRAXIS' menu item that is set as your homepage. Setting the slideshow to appear on the 'PFERDEPRAXIS' menu item has resolved the issue.
uhhhh I am so sorry...now its on me to blush :-)))
THANK YOU AGAIN and im really sorry for bothering you with my stupid mistakes...
regards marion
