1. FCPeggy
  4. Wednesday, 13 July 2016
Hi, If I lived in Ireland I'd most definitely buy you lunch for your continued, excellent support.
Metropolis and Fedora templates - the Joomla 3.5 Templates/Edit Style "Responsive Options"
Responsive Style = YES
Use the following options to turn On/Off each set of modules on mobile devices (less than 720px) - Image below - all set to YES
They ALL show when I test two websites, one I did with Fedora and the other with Metropolis.
For mobility responsiveness I would like to turn off the "Top-1" Modules.
How would I achieve shutting off any of the module positions?
I cannot give you access to any of my work since it is on my laptop. Any advice would be appreciated.
Hi Peggy
Presuming I understand you correctly I believe setting the 'Top-1 Modules' option to 'No' will give you the desired result. These options indicate if the module position is On/Off rather than the state of disabling the module... hope that makes sense.
I'm having a very Canadian "deer in the headlight" moment.
Works perfectly and makes sense now.
Thank you yet again!
