1. ziggy
  3. Pre-Sales Question
  4. Wednesday, 13 February 2013
I recently purchased the Endeavor template for my Joomla! 1.6 site. I fear that Endeavor may only be for 1.5 and it is not working with the site. Is the different software the source of this problem, or is there another possible reason why it is not working? If the improper software is the reason for the problem, is there anything I can do to fix it?
Hi Brandan
  2. Pre-Sales Question
ok, i did that. i think. im not really sure how to do that. sadly
Thank you Brandon
I have reinstalled your template and it now appears to be working correctly.
  3. # 3
Thanks for that, but now I am also noticing that the side menu is not working, or even showing up at all.
  3. # 4
The position of your side menu module will have to match that of the side column position of the template in this case called sidecolumn. The position of your module can be set via the modules parameters.
  3. # 5
ok thank you very much, you've been a huge help.
  3. # 6
