1. Aray
  4. Tuesday, 30 July 2024
had any of you ever had the problem that the three contentbottom modules are not displayed horizontally?
Thank you for your solution hints.
Aray
There are three call-to-action modules that are not displayed at the same height.
I have now used three custom modules. Unfortunately, a new problem appeared there.
The "Read more button is not displayed as shown in the screenshot.
Why is that? :(
Try setting a 0 value in the Vertical Margin field for each instance of your Call to Action module.
CIaran
thank you for your correct setting hint!
Unfortunately, I have a bigger problem.
My six contributions for the J51_News module are unfortunately not accessible from the homepage. We already had this problem with another project, but I don't know how you solved it anymore?
Could you take a look at the link?
  1. https://gwoe2.mgmb100.de
Did I send you by email
Thx for your Support! :)
We are still awaiting your email with details to access. Any email related to this URL does not appear to include any details.
The second time I have sent an email with the login to cira4n@gmail.com and now also to info@joomla51.com.
why don't I get an answer - You wanted to look at the template NINA with the problems? I sent you the login on your e-mail request!
Did something happen to you?
Greetings
Aray
