1. Aray
  4. Tuesday, 24 September 2024
Hi Guys,
there is also a problem with my next Joomla4 project, this time with the NATALIE template and that shortly before completion. :(
Only the first two blog posts on the start page are displayed correctly, the other four posts are displayed before the slider!
I also tried to recreate the affected posts, but these are then attached right after the slider??
Does anyone have a hint for problem solving?
Thank you very much
Aray
  1. https://bst24.mgmb100.de/index.php/blog/90-desinfektion
I have now reused the blog posts for a news module - again, only the first two news posts are called correctly - but the other four posts are displayed before the J51 showcase?
  1. https://bst24.mgmb100.de/index.php/news/113-schimmelbeseitigung
those images aren't related to the content, that's why they appear elsewhere.See your page Bautrocknung, it's in the article
I still had the image link from my first attempt as blog posts! But even after I have now linked these to the News Media folder, the problem is not solved? The post title image of posts three to six will still be displayed above the slider?
Go to the article, select tab images and links
select full article image and add your image
then in image class select left and save.
your article should look like your article Bautrocknung
Hi Franc,
best thanks for the right hint. :)
Greeting
Aray
