1. Digijoom
  4. Tuesday, 05 September 2023
I'm using the template Juliet for a multilanguage site (Dutch and French).
I made two templates and 2 menu's.. One for each language.
Everything works correctly. But when I'm somewhere in the French website and click on the name/logo (which is the home normally) then I got the Dutch homepage instead of the French homepage.
I don't have this problem in other multilanguage websites.
When I go the the global configuration of Joomla4 and set the SEO URL disabled then it works fine and I do get to the French home page. But I want the SEO url enabled of course.
What is wrong here?
Kees
Hi Kees
Thank you Kees
To amend we have changed the URL in each FR style with some JS by adding the following to the Head Custom Code field of your templates stlyes parameters (Extensions -> Template Manager -> YourTemplate -> Custom Code -> Head Custom Code)...
<script>
document.addEventListener("DOMContentLoaded", function() {
const logoLink = document.querySelector(".logo a");
logoLink.setAttribute('href', "http://whatever.com");;
</script>
Replacing http://whatever.com to the new URL.
Thank you Ciaran,
Strange that this was necessary and it is not default.
But anyway it is fixed.
Kees
