1. vtom007
  4. Friday, 03 May 2019
I'm using the template j51 juliet and hve a problem with the display of input fields, with text areas only one line is displayed instead of several. The effect occurs with all browsers, with Firefox I can pull the field bigger. Not in the Edge.
Assume the effect since the Joomla version 3.9.2 occurs.
Best regards
Tom
Hi Tom
Is the field in a module or a component?
Sorry, but this web works only as a intranet system in a company :-/
Both, i see this mistake in a Modul (include a Component from RSForm) and a Component: Kuena Forum.
In the Edge browser its only one row, in the firefox its to one row but can be enlarge with mouse
Tom
Hi Tom
To allow us to try and replicate the issue could I ask you to do the following...
1. Open in Firefox
2. Hit CTRL/CMD + F5 and click on the form element
3. On the highlighted element in the inspector panel, right click and select Copy -> Outer HTML
4. Paste the result here.
OK
<textarea class="span12 markItUpEditor" name="message" id="kbbcode-message" rows="12" tabindex="7" placeholder="Textfeld für den Beitrag." aria-invalid="false"></textarea>
Does adding the following to the Custom CSS field of your templates settings resolve the issue?..
select, textarea, input[type="text"], input[type="password"], input[type="datetime"], input[type="datetime-local"], input[type="date"], input[type="month"], input[type="time"], input[type="week"], input[type="number"], input[type="email"], input[type="url"], input[type="search"], input[type="tel"], input[type="color"], .uneditable-input {
height: auto;
line-height: 1.3em;
