1. mrdansken
  4. Monday, 13 April 2015
Hello. I wonder how one can have more than one menu in the same space. I need to switch between languages in the main menu and do not want Google Translate but my own. I have created three menus but find no way to switch between them?
You have 2 possible options..
1. Select a Template style in your 'Template Manager' (Eg. Central - Default) and duplicate it for each language you want. In each of the styles then select the menus to be displayed for that language. You can then set that template style to the langauge via the 'Languages' dropdown or by assigning the correct menu items via the 'Menu Assignment' tab.
2. Within the templates parameters you will see an option to convert the menu to a module position. Once selected you can then create a menu for each language set to the 'hornav' module position.
