With installing the demo content I often had trouble. After uploading all files and starting the Joomla installation, joomla could not connect to the database. I found out, that there was a .txt file within the main file directory of the uploaded files which just needs to be deleted. After deletion the installation process was no problem anymore. Ciaran, maybe this should be fixed within your demo files?!
By default, Joomla does not allow you to upload SVG format. May I suggest sending temporary administration access to your Joomla installation to [email protected] and add your logo manually. Please include a URL to your SVG. Your template will source this URL for your logo image. For our reference please paste a link to this post in your email.
Here is the svg file that represents the logo of my PlanetHoster host.
I send you the following link (url): '' https://www.planethoster.com/goph-michel-six ''
Embed this logo in the middle of footer 1 or 2.
I just got the imag of the logo and the link, it works, but there is still a white planethoster to eliminate, otherwise it's okay.
The time to find the solution in svg … ^^
Bonjour,
Je me suis contenté d’intégrer l’image du logo et le lien, ça fonctionne, mais il reste ‘planethoster en couleur blanc à éliminer’, sinon c’est ok.
Le temps de trouver la solution en svg … ^^
I have a problem with header that I have mistaken to put a side menu (which I have disabled right now).
It is still displayed in Header 2.
How can I solve this?
Regularly, 6michel
PS: for the hosting logo, I manage with an imaging logo and link, it's ok !
Nota: If you want my password and identifiers, I'll not pass it on to you outside the forum. Tell me?
Another question: can we add a code that will accept svg/xml files?
Because I managed to put the svg file in media/images/…on the other hand, I can’t insert it.
Thank you for your return,
Regards, Michel
1 .Would you have a URL to an example of your menu in the header-2 position?
2. Unfortunately, for security reasons, Joomla does not allow the selection of SVGs. Your only option is to edit your templates layout/logo.php file (../templates/YourTemplate/inc/layouts/logo.php) and add your SVG image manually.
