one short question about the new template Hayley.
Is it possible to set a sticky header or menu? Is this a default option in th e template configuration?
I only ask because I see no sticky header in the examples.
A sticky option is available for the logo area of the template. This can be switched to the menu with a small customization, however, is not possible to stick both the logo and the menu.
For me and my customers its important to have a sticky menu, the logo is not so important. People should be able to switch pages without scrolling up to the menu again and again...
So if there are possibilities to get the menu sticky, than its fine and I will buy it.
I have to come back to this thread. If I should repost it in another forum area, let me know.
Where do I have to customize it to set the logo sticky and not the header?
Is it in /inc/scripts.php line 82 to change ".header_main" to ".header_hornav" ?
