24 HOUR FLASH SALE - 30% OFF EVERYTHING - Enter coupon code 24HOURFLASH on any purchase!
  1. maurilla
  3. Thursday, 24 May 2018
Hi, after upgrading to the latest version of Joomla (3.8.8), "creative" template doesn't work (error 404 on home page).
I've also tried to replace it with others (newer) type, but they don't work too.
Switching to the standar templates (like protostar) everything it's ok.
Why?
Thank in advance for your help.
Does disabling all modules resolve the issue? If so are you using Joomlas random image module?
Oh, yes Ciarán.
Module that gave trouble is random image.
Now it's ok, problem solved, thanx.
No problem
FYI..
This is a known issue with the Joomla 3.8.8 update (https://github.com/joomla/joomla-cms/issues/20531).
A fix has already been created and will be available with the next Joomla update (https://github.com/joomla/joomla-cms/pull/20533).
In the mean time you can apply the fix manually... https://github.com/joomla/joomla-cms/pull/20533/files
