1. crimle
  4. Tuesday, 12 February 2019
I have two issues with the template Caitlin.
1 // On mobile screens there is a considerable margin to the left of the screen.
2 // Underneath the header image, we have the main navigation. On mobile screens, this navigation should go away and be replaced by the mobile menu. The mobile menu is there and the navigation items disappear, which is ok. But the gray "container_hornav" remains there. I guess it should not be.
Thank you and kind regards
Chris
  1. https://www.quartierverein-kurzdorf.ch/
Hi Chris
@media only screen and ( max-width: 767px ) {
.block_holder,
body {
    padding: 0;
.maincontent {
    padding: 20px;
#container_hornav {
    display: none;
superb! It works!
Chris
