  1. Bugsys
  3. Friday, 28 February 2020
i just wanted to update the template Bianca on the admin page, because he wanted to update the "J51 ImageHover Gallery". Unfortunately this is no longer possible. Then I saw that I have only 3 months "support" for this template Bianca, or only as long as I can download it.
Is that correct?
This was not the case with the other templates I already bought.
Did I miss something with the last purchase?
Did you change something there?
Thanks for a short info!
Greeting
Helmut
Hi Helmut
My apologies as this appear to have been applied to your purchase in error. I have amended your account and you should now be able to access the Bianca template download.
As in the template, I can remove the horizontal bar above the logo that can be seen on the page https://spnsasiedzi.pl
thank you in advance
Darek
Hello Ciaran!
Thank you very much!
Perfect support as always! :D
Helmut
Hi Darek
Have you since revolved this issue as there no longer appears to be a visible bar above your logo?
Tak udało się.
Dziękuję
Darek
