I am wondering how can I turn off the compatible view on IE10 with meta tag?
my site is almost completed, and I find that my site appears correctly on all browser except on IE.
I haven't tested on the other than IE10, but if Compatible view is turned on, then my site doesn't show up correctly.
If the compatible view turned off, then the site appear correctly.
I have searched about that  and if I add the meta tag <m-eta http-equiv="X-UA-Compatible" content="IE=9; IE=8; IE=7; IE=EDGE" />  after the title meta tag, it suppose to  work.
Is it correct? and how can I add the meta tag?
my site is http://www.nevo.sa.edu.au
