1. bibbp
  4. Tuesday, 02 July 2013
I can't get the ImageLinkHover module to install, with this error:
JInstaller: :Install: File does not exist /home/linweb17/a/http://ashwoodphotography.co.uk/user/htdocs/tmp/install_51d340d8ef75f/mod_j51imagelinkhover/images
I'm using Joomla 2.5.9
We hope to have now amended this issue. Could I ask you to re-download your template and reinstalled your j51_imagelinkhover module.
Thank you Ciaran for the update, we're nearly there. The ImageLinkHover now displays a directory where I think it should show a single image, and I can't now get the thumbs gallery module to show different images from the same directory...the old did show different images but in a straight line. if you wish to see what I mean please look at my testsite http://www.ashwoodphotography.co.uk/testsite/ thank you!
Peter
Hi Peter
For best results with your ImageLinkHover module ensure the images you use match the same width and height of that in your modules parameters.
Sorry to say at present there is no option available in the ThumbsGallery module to display certain images from a particular directory. May I suggest creating a separate folder for each of your galleries.
