Hi Cirian,
I administrate the homepage of my athletic association. Because at the time there is a strong coming up and going down of sections and this is a problem with the width of the horizontal menu. Dropdown menus are a solution. I think a update for my actual template Metropolis to Multi Column Dropdown Menus is difficult and so it would be the better way to change to a new template, which is compatible to Joomla 4. Some sections e.g. the soccer section have 10 teams and everyone has a site. Is it possible e.g. in the Stella template to create dropdown submenus in the Multi Column Dropdown Menus, which works like the mobile menu?
Best regards
Peter
