1. milian
  4. Saturday, 04 January 2020
I am using the PianoForte template.
Is there a parameter available for the custom CSS to make the Arrow for the sub-menus darker?
In the attachment the red arrow points to the almost invisible sub-meu arrow.
Or another way of doing this?
Thanks and regards,
Milian
Hi Milian
The Pianoforte template uses the following image for the menu parent indicator.. ../templates/j51_pianoforte/images/arrow_down.png
Try editing this image directly to the darkness you require. Sorry to say as the indicator is image based, there is no CSS only solution.
Thanks Ciaran
I changed all the arows in PhotoShop for a better corporate look.
down
down_over
right
right_over
regards, Milian
