1. arsd
  3. Tuesday, 21 July 2015
hi guys with another account I bought the cashmere's templates now on site of my client http://www.irpinahospital.com/ when i resize the window of my web browser i don't see sub menu anymore, this isn't the first time that i use cashmere and i never had problem... i can't unistall my pulgins they are fondamental and i tried with easy jquery but nothing still same issue... can you help me?
Thank you Arsd
You appear to be using a very old version of Joomla. Have you considered updating to at least Joomla 3.x as 2.5 is no longer supported by both Joomla and most extension providers. Mainly for security reasons, it is suggested to ensure you have the latest version of Joomla installed. This will also allow you to use the latest version of your template which should resolve this issue. Template updates are no longer applied to the Joomla 2.5 version of templates.
thanks a lot for solving the problem!!!
Jurgen
HI Juergen
I have installed and set up 'jQuery Easy' and your menu appears to now working correctly. The conflict appears to have been with your JoomGallery plugin.
I notice that the access details sent were for a different site than what's mentioned above.
Hi Juergen
today I recognized a similar problem with the cashmere template.
In the mobile version the submenues do not appear after clicking the menue button in the mobile version.
Tried another J51 template for the same installation and the menu button works fine
Juergen
Hi arsd
