1. Iankellett
  3. Thursday, 07 November 2013
Is there somewhere where I can get the different colour styles of Kindle without having to go through all the parameters please?
We can post a set of screenshots for each style if that would help?
what I had in mind was the example styles you had being downloadable as templates along with the default ones which would save going through and changing each parameter.
The only option I could suggest is using the Demo Installer included with your purchase. This is a copy of Joomla with the template demo included as its sample content. This will include each of the example template styles.
I too would like to have one of the example styles for Kindle.
Idon't remember if I installed the demo-installer or just the template, but in my template manager I only have listed the default Kindle, Hathor, Beez5 and Blue Stork templates.
If this means I only installed the template not the demo-installer please post screen shots of the parameters for example style 6.
If there are options to select a different template or style sheet that I may have missed please give instructions on how to find them.
Many thanks
Hi Judemac
If using the demo installer you will find a style available in your template manaber for each of the example styles so I suspect that you simply installed the template...
An alternative solution to access all the styles would be to install the demo installer locally.
