1. chrishoefliger
  4. Tuesday, 11 January 2022
Hi, Ciaran
I am currently working on upgrading a site to Joomla 4. It used to run Ariana, unfortunately that's not available for J4, so I decided to use Nina instead. When I came to setting this here icons module, I saw two things that seem strange:
- setting the icon color does not really set the color of the FontAwesome icons, the module seems to use the color set as primary.
- Icon desriptions appear underscored, same as normal links would, looking ugly. I solved this by using
.j51_icons a:link {
text-decoration: none;
The module used to run perfectly on the same site when it would run Jooma 3.10. latest
The module claims the version number 2.0.14 when I last checked, this is the version being shipped with all newes J4 templates I have obtained. As the site is currently under development on ma machine, there's no link available.
Any suggestions?
The problem has been resolved with a re-worked icons module.
Thank you, Ciàran
Hi Chris
Thank you for your patience on the issue and for the update.
May I ask what version of the template are you using? The latest is currently 1.0.5. If you haven't already, try updating to the latest version and see if the issue persists?
Thanks Ciaran
I am using V 1.0.5 (see attachment)
Chris
I am not a dev, but when I remove the marked part of mod_51icons/tmpl/default.php, I am able to set the icon colour
In the 'old' version (ariana) there used to be an if-clause to check if an icon color is set and only if not, it would use the primary, like
<?php if ($j51_icon_style !== 'none') { ?> background-primary<?php } ?> text-primary j51_icon_style_<?php echo $j51_icon_style; ?>
This is no longer there.
Thank you for bringing this issue to our attention. It appears the Bootstrap 5 loading with Joomla 4 uses !important for some of their utility classes which overrides the colors by the template settings. The idea of the text-primary class mentioned is added as a fallback if no color is set in the settings.
To resolve please install the attached update.
Thank you, Ciaran
I have installed the updated module, I gather that the version is now 2.0.17 - that's what the back end tells me. Unfortunatelly the problem with the colour of the icons has not gone away, whereas the underlined links are no longer a problem.
Hi Chris
Hi Ciaran and thank you. I have created an admin account for you (details see email). I downloaded the latest Nina version and updated both the template and the module.
Thanks again, Chris
