1. jason_csh
  3. Tuesday, 03 March 2015
I noticed that on the Stockholm template, if I switch to using logo text instead of an image it breaks the dropdown menus in the menubar. You can vaguely see the dropdown appear but vanish straight away. Switching right back to use an image for the log sorts it out again.
Any suggestions?
Many thanks,
Jason.
Thank you Ciaran, I'll make the change with the custom CSS method.
Jason. B)
This fix has been applied to the template download.
Hi Jason
Thank you for bringing this issue to our attention.
To amend you can add the following to the Custom CSS field of your templates parameters...
h1.logo-text a {
display: inline;
width: auto;
