I'm trying to add in product images with a button (this is not a online shop) as per the layout on http://dev.web-guru.co.za/pawnshop/i-want-to-buy/appliances-menu.
Tables didn't work as it kept losing its responsive settings (imported from Dreamweaver into Joomla articles). I tried using div tags, as per your suggestion - works but comes up as not mobile friendly on https://www.google.com/webmasters/tools/mobile-friendly/ > error content wider than screen.
Have now set it up as a category blog - and it still says the content is wider than screen.
Please can you give me a suggestion how to get around this. I literally need a main header with 4 columns underneath (one to hold text and a button, the other 3 to hold images).
Thank you so much!
