1. Mol4
  4. Monday, 04 September 2023
Unfortunately the sticky header isn't working while working on the site.
I have to clear the browsercache in order to make the header sticky again.
Is there some workaround here?
Thanks!
On my clients testsite (i think I say this every time :D ) I can't get the sticky header/mainmenu to work.
In the template section all the instances of the template I've set the Sticky Header to 'Yes'.
But unfortunately it doesn't work.
How can I fix this?
Thanks!
Greetings Ton
Hmm, it seems that everytime I'm working in/on the site the sticky header isn't sticky anymore.
But when I clear the browser cache the sticky header is working again.
Is there something I can change so he sticky header will work constantly without clearing the browsercache?
Thanks!
Greetings, Ton
Hi Ton
It is difficult to say as it depends on the content of your cache. Checking the URL provided, your header is sticking for us, without having to clear any cache.
Oké, I will use two different browser while working on it, thnx!
