On my clients live-site the Sticky Header is set to 'on' but doesn't work all of the time.
This is for desktop as well as for mobile.
Can you please have a look where things are not going right?
They use the Magnolia template.
Thanks!
- Mol4
- Wednesday, 08 November 2023
It looks like my questions are answered but it can be I'm not making clear enough what the problem is.
When I set the header to 'sticky' in the backend the problem is that the header-image is also sticky.
But I think we try another template and see what happens.
So this ticket can be closed.
Thanks!
Greetings, Ton
Thanks!
Greetings, Ton
I've send the site credentials a while ago.
Any updates yet?
Thanks!
Greetings,
Ton
Any updates yet?
Thanks!
Greetings,
Ton
Alle the best for 2024!
Any updates yet?
Thanks!
Greetings,
Ton
Any updates yet?
Thanks!
Greetings,
Ton
Hi Ton
I dont appear to be able to locate these details. Could I ask you to resend your details and to ensure to include a URL to this post for our reference.
It is solved now for the sticky header but now the header images are also sticky on mobile and desktop.
This should not be the case.
Thanks!
Greetings, Ton
Thanks!
Greetings, Ton
Hi Ton
#container_header {
position: relative !important;
}Ciaran
When I use this lines of CSS-code the header isn't sticky anymore.
The logo and hamburger navigation should stay in position (top of screen) on mobile, tablet and desktop.
The header image should not be sticky.
Greetings, Ton
Greetings, Ton
- # 9
Hi Ton
When I examine your site on mobile, nothing appears to be sticky. To amend try adding the following to the Responsive Custom CSS fields within the General -> Responsive Options tab of your template settings. For more details on using these fields may I suggest the following article... https://joomla51.com/tutorials/template-parameters/applying-custom-css-to-a-screensize-device
[code].header_sticky {
position: fixed;
top: 30px;
.header_spacer {
position: fixed;
top: 0;
}/code]
position: fixed;
top: 30px;
.header_spacer {
position: fixed;
top: 0;
}/code]
- # 10
