1. cmobowmen
  3. Sunday, 19 March 2023
I can't get Eshop to display using the Stella template. Tried changing PHP version and made sure everything is up to date including Stella (although it still display v1.02 even though I have installed v1.03) but no luck.
I have also tried installing the jQuery fix plugin.
There seems to be console errors suggesting that the variable jarallax is missing.
Please can you help?
Martin
  1. https://sarahwaltonjewellery.co.uk/index.php/shop-menu
Yes the issue was with the eShop and the language settings for the site not being setup correctly, and not template-related.
Thanks for your help.
Martin
Hi Martin
Thank you Martin
Have you since been able to resolve this issue? When we check your shop we are presented with a notice from EShop stating "Our Shop is currently down for maintenance. Please check back again soon.".
Admitedly I am not very familiar with the component however it seems that the component is loading but offline?
