1. Kyna
  3. Thursday, 02 February 2023
I have the Stella template running with Joomla 4.2.7,
Since I activated the Slideshow mudule my Main menu and Logo are in wrong positions.
Further the footermenu position is not appearing.
What can we do?
Best wishes
Kyna
  1. https://4er.knotenkunst.net
#container_footer {
position: relative;
To amend try adding the following to the Custom CSS field
#container_footer {
position: relative;
Thanks that worked as well :)
Kyna
At what position did you publish the slideshow?
top 2a, but showcase 1a gave the same result :-/
Hello Ciaran
Yes thanks a lot - it worked :)
But what about the footermenu? Still no footermenu position availible :(
Kyna
