this is not a question but something I figured out myself :-) haha.
Maybe there is a more simple solution but with al the work I had and trying I've done this might be something for others.
The 'thing' I had was when using the ul.star on an unorderd list to get the little star-images in front of the list, on mobile the stars where centered at the list-text. I couldn't get the stars aligned on the first sentence.
So I decided to fix this.
But really it isn't a fix because I removed the original stars and made some new stars with the use of an unicode symbol.
Here is the CSS I added tot the custom CSS.
It worked for me :-)
/* to align the bullet-stars at the first sentence of list-item on mobile */
ul.star li {
background: none;
ul {
list-style: none; /* Remove default bullets */
ul li::before {
content: "\2605"; /* Add content: \2605 is the CSS Code/unicode for a star*/
text-shadow: 1px 1px rgba(0, 0, 0, 0.4);
color: gold; /* Change the color */
font-weight: bold; /* If you want it to be bold */
font-size: 20px;
display: inline-block; /* Needed to add space between the bullet and the text */
width: 1.2em; /* Also needed for space (tweak if needed) */
margin-left: -1em; /* Also needed for space (tweak if needed) */
/* END to align the bullet-stars at the first sentence of list-item on mobile */
