1. PLM
  3. Monday, 04 June 2012
If you visit http://www.louisvillelarp.com, you'll notice the beginning stages of our website. Currently the only available "working" portion of the site is our forum.
When you click on forum, you're prompted with the logon. Once you're set and able to view the entire thing the forum is chopped off at about 25%. If you click on a forum link to view a topic, the forum corrects itself and looks as it should.
I'm assuming this is a code issue and it's been years since I've tried to manipulate html without someone telling me exactly where to go/what to change.
Is this fixable?
I'm using "Kunena" for my forums.
Hi PLM
Is your URL correct (http://www.louisvillelarp.com,/)? It appears to be giving us a 404 error.
It looks like you included a comma at the end of the URL. It's fine without the comma.
May I suggest adding the following to the Custom CSS field within your templates parameters..
[code type=css]#content_full {width: 100%;}[/code]
That appears to have fixed the problem. Will this effect every page that opens up now? I'm hoping to still utilize the side columns and whatnot. The forum is the only page that will open up as one single entity.
Thanks for the quick fix. It was so simple!
The above CSS will only effect pages with a full width content area (no modules in the sidecol positions).
