Hi there, so sorry to bug you. I recently upgraded Joomla via admin panel, and the articles once again display with very little space between them. Previously you suggested adding:
.items-row {
padding-top: 30px;
This was via the additional css facility and worked fine. Now, however, it does not seem to be reading it at all. Is there something in the new Joomla that disregards this? I did try searching for .items-row in template files themselves but found nothing, so I'd appreciate your assistance. I have attached a screen image showing the display with little space between the end of one post and the header of the next.
Many thanks,
Jude
- Judah Raine
- Sunday, 06 July 2014
Hi there, thanks for responding.
The example I posted (image) can be found at http://judahraine.com.
Since then, I have noticed that the other site is also doing odd things:
http://classicromancerevival.com/index.php/about - this displays perfectly, but on the same site
http://classicromancerevival.com/index.php/affiliates has no space between the articles at all
The actual text (body text) seems to have the padding applied to each row.
I do appreciate your help, thank you.
Jude
Jude
Thank you Jude
To amend could you try adding the following to the Custom CSS field of your templates parameters where 30px is your bottom padding for each article (edit to taste)...
The same CSS should work for both of your sites.
.items-leading > div {
padding-bottom: 30px;
}The same CSS should work for both of your sites.
Hi there, thank you so much. This worked perfectly!
And now, hopefully, a final question. At the end of the article I want to display the author details. This works fine, except that it shows the word Details as well as the Written by Judah Raine. Is there any way to remove the word Details? It just seems a little silly.
Many thanks for all your help
Jude
Jude
Hi Jude
To remove try adding the following to the Custom CSS field of your templates parameters...
.article-info dt {
display: none;
}Ciarán
