I am building a site using the excellent classic template. Up until now all has been smooth and the small customisations I needed to make were fairly simple. But I have hit a problem and after hours of trying to fix it am no nearer a solution. Any help is much appreciated.
There is barely any space between the Read More link and the next article header. How can I create it? I have added a near empty ghost article and omitted the read more (should this be a button?) and the space seems okay. But I need the read more button to make the site look as I want it to. Does anyone have a solution?
Site
http://www.cardiolefrog.fr/
- lorenzo
- Free Templates / Extensions
- Tuesday, 04 August 2015
Hi Lorenzo
To resolve try adding the following to the Custom CSS field of your templates parameters (edit to taste)...
.post {
margin-bottom: 30px;
Thank you Ciaran,
I tried this buit there is no change. The custom css now looks like this
/* Custom CSS */
.post {
Is there anything else I should be doing? Do I need to create overides in order for the custom css to work?
/* Custom CSS */
.post {
Hi Lorenzo
Just to confirm, you have added the suggested CSS to the Custom CSS field, not the custom.css file?
Many many thanks . I figured what the custom css field was and posted the code. Worked straightaway.
One more thing. On the demo the read more is a lovely blue button. All I have is a line of text. Is it pretty straight-forward to change this?
Your Custom CSS field can be found by navigating to Extensions -> Template Manager -> [YourTemplateStyle] -> 'Custom CSS' tab.
adding
.post {
to costum-css does not work on your emani-template.
How to add mor space between articles there?
Thank you!
Mirko
adding
.post {
Thank you!
Mirko
https://homepagejoomla.live-website.com/index.php/aktuelles
Site is in progress ;o)
There are also the "Introductory images" in the blog, that i cant remove
- # 10
(edit to taste)
(edit to taste)
.blog-items .blog-item {
margin-bottom: 3rem;
- # 11
ok, that works perfect!
For the problem with the images you have no idea i guess?
will be a joomla-thing i guess.
Thank you for your help!!!!
- # 12
