1. Edgar68
  4. Wednesday, 24 June 2015
i've got a question.
On my website kaasbox.nl on the homepage,...... the space between J51 Caroussel en J51 slideshowmodule is perfect.
But when i look on mobile device, the space between the modules is to large.
How can I resize it to normal proportions?
Gr
Edgar.
Hi Edgar
To amend try adding the following to the Cusotm CSS field of your templates parameters (edit to taste)...
#owl-carousel130 {
margin-top: -80px;
Hi Ciarán,
it does not seem to work.... :-(
Gr Edgar
Hi Ciarán,
I tried again, but it is not solving the problem :(
Gr
Edgar
Hi Edgar
Thank you Edgar
The issue is related to your slideshow image dimensions. As slideshow images will always remain 100% width, images are not big enough in height to fill the space specified within the slideshows settings on smaller screen devices. I have added some CSS to the Responsive Custom CSS fields which will help however an alternative solution would be to increase the height of your slideshow images so they can fill the slideshow on all screen sizes.
Hi Ciarán,
I did what you suggested
it is now much more acceptable.
Thanks for your help.
Edgar
Hi Ciarán,
There is still an problem,
On Mobile device, the space between caroussel and slideshow in Dutch language is ok.
But when you look on English, the caroussel is show mixed with the slideshow.
Gr Edgar
Hi Edgar
Greta support...
Thanks Ciaran
